Does anyone make a aftermarket pole bracket that fits the DVX hulls.
Does anyone make aftermarket pole bracket that fits on DVX hull? That fits with the pole that comes on ski. My loops on the pole bracket keeps coming loose. On my fifth set of ears. Lock tight the crap out of and still the right side loosens up and the pole loosens up. Won't stay tight. Any suggestions. Has anyone else delt with same issues.
mike b
California
I installed a set of bolts with a castle nut where I can run a cotter pin. It stayed tight for a long time but now we need to get tightened up. I think that's actually because of the bushings not the pin letting loose.
That has resolved that issue for the most part. The only other issue I have with the pole bracket is when you do enough spins the pool will start to get tweet and your full no longer looks straight on the Hull. I do a lot of spends so my bracket gets tweet fast and it's pretty obvious. To remedy this I plan on buying a new bracket and ears. With the new bracket I plan to get the ears welded so they are not able to shift and install the pole and bracket all-in-one. It will take extra time but should only need to be done once.
