Dome size
I live at 5,000 ft in Colorado. Going to be installing ada head, factory pipe, and advancing timing on a stock fx1 with a 17/22 skat swirl impeller.
What dome size would be good for running 91 pump gas? 33cc or 31cc? I do not know my compression currently, but it is a healthy stock 701, rides great.
usa
yes for sure
i have usd ada heads since they started making them
33cc for 2000-3000 ft
35cc for 0-2000
you also can have custom ones made for 1000-1500ft 34cc
keep in mind this is for stock un-ported un-decked 701-718cc cylinders
add a msd inhancer too if running stock cdi
I'm in fortcollins(5,000ft), also run ada head, 31's=180-185 33's=165-170, I run 31's on pump gas no issues with 3mil advance, enhancer, drypipe, and ported, I've found that 195 is the mark for race fuel at least for my boat, I'd think your fine with the 31's but every combo can be different, if it pings put the 33's in or blend race fuel with your pump gas but you should be fine, 31's are really the go-to domes around here, just about all my sj buddies with Ada heads run 31's on pump gas
