Other Double decker stand
SW FL
Has anyone made a stand for two skis, one on top of the other. I have a 8 foot by 2 foot spot where I keep my ski. Now I have two and want both to fit there.
My idea is make a high and a low stand and have to low stand roll under the high one. I will be a SN and a Gen2 BOB
dragginblazer
Do Good Jetski Crew
I have one in my shed made out of 2x4s that holds a x2 on the bottom. Pic when i made it...
If you want to build your own, wood (as above).. If you want to buy parts - Home Depot has these "mini pallet rack" type jobbies... Something like this, but there's a cheaper one somewhere, $500+ is nuts... But, 1800 lbs is also overkill...
Here they are, found them.. $34/upright... 72"H x 24"W...48" cross member is $10, 96" is $20... I think you'd have to go longer because you'd have to lift them in sideways, versus the "front" attack method...
