Drive Coupler Removal Tool
Hey guys I'm checking to see if anyone has knowledge of a tool I saw that someone made to remove a drive coupler. It was just an impact socket with 3 pieces of angle iron welded to it. I saw it a couple days ago and for the life of me, I cannot find it again. Does anyone have pictures of one they have made? I need to show it to my friend so he can make it, I'm having a hard time describing it. I know companies make actual tools, but I can have it made at a fraction of the cost. Any hep would be appreciated!
OCD Solutions
Rentz, GA
Simple 3 finger style I made up years ago.
It works but it twists a bit so making it out of a thicker material would be better.
BruceSki
Formerly Motoman25
Long Island
Out of 50 flywheels or more I've pulled, I had one ever, that separated the wheel from the ring gear.
It was a 760 flywheel and the ski ran like a bag of poop which tells me the flywheel was already spun before I held it back with that flywheel lock tool. I just broke it 100% once I put a ratchet on the bolt while the wheel was locked.
OCD Solutions
Rentz, GA
With rope in the cylinder or with the wheel lock?
I have done the rope trick once or twice, used a piston stop tool for years and now use the cold fusion flywheel lock.
The flywheel lock is by far the simplest and safest method to date.
