SX/SXi/SXi Pro Drive shaft lengths?
I am in need of drive shaft lengths. I am about to install a set back mag pump in my ski. I am currently using a 750 sx shaft. I need a drive shaft slightly longer. I believe most kawi use the same prop spline so any shaft would work as long as its longer than a 750 sx shaft.
Thx in advance.
I thought so. They moved the motor forward to better balance the hull if my memory serves me correctly. SXI pro vs SXR?????
Is the SXR shaft longer than the sxi pro????
Yes it is 1 3/4" longer, you have to be careful on the machined area lining up with your bearing support. You would probable be ahead just buying a longnose impeller, that's what I did.
