Myself
manic mechanic
- Twin Lakes AR
Quick and easy method to straighten out a bent driveshaft. You'll need a set of V-blocks, a dial indicator with holding fixture, and a press. BUT.....I've done this in the past using Lego's as V-blocks, dial indicator clamped to a block of wood, and a big brass hammer as the press. Hey, you work with what you've got.
Set the shaft in the V-blocks and use the dial indicator to check runout at BOTH ends, AND about every 2" a long the length. Use a sharpie to mark the highest point of runout. This one started well over .030" bent!! It was also crooked more in one direction.
Here is the shaft after I marked runout. Those numbers are thousandths of runout.
