650/X-2 Dry pipe dual cooling line routing?
gold408fox
Ride or Die.
Lansing, MI
I'm a bit of a newb.. and I hate to ask the age old question of cooling line routing but I just can't seem to find anything that depicts my particular set up. I have a 650sx with a pjs head, dual cooling of course. I'm currently trying to dry pipe my ski. I have the hole jb'd and drilled to 1/8 inch, and the nipple cut/ welded, with the stinger nipple welded. I just can't quite figure out the routing of the cooling lines. There is a drain line from the pipe that will no longer be used.. can I use this for my second pisser? Also where is all of this water coming from? Every diagram i see seems to point out that both nipples on the head have water coming out of them. I am very confused and a little help would be great.
