I want to experiment with full time water injection on my type 4, not using the controller or solinoid. Was thinking of a water filter, then a flow control valve to turn it on somewhere off idle, and perhaps a restrictor to limit the water to the spray bar. And yes, I know it will probably loose a tad bit on top end. I may also add a mini pisser to tell me when the system is on. The idea here is to gain more bottom at the expense of some top end, but don't want the added complexity of the additional electronics on board. Anyone ever try something similar?
