- Charlotte, NC
ive got a full 62t engine with dual 38s. a friend has a set of 44s to trade. its a stock 62t/62t engine for now with a c4 chamber bpipe. what carb settings should i start with on the 44s? i believe they are stock 44s off a 760
Get the pump worked out first. Stock or standard SBN44s will make the pipe hit a little harder. Not difficult to tune but will require a little richer pilot/popoff setting than 38s.
Heres what I ran with Dual 44s on a 701 with a B Pipe.
H 145 - Start with 1.5 turns out and work from there
L 125 - 1/3/8 Turns
N/S 2.0 (Gold Spring) 19 PSI
I have a Mikuni speed plate that can fix that problem for saleJust to throw this out there, the intake manifold is different between the two carb sizes if you're using oem Yamaha intake manifold.
So trade the whole setup if you're going to do the trade.
I have seen those and while they work as a cheap alternative, You are leaving horsepower on the table in my mind. My jetting spec listed above is for 760 44s.A mikuni speed plate can make a 38mm hole in a 38mm manifold increase in diameter to 44mm???
125 low
115 high
2.3 needle and seat
115 gram spring
b-pipe with top two closed and bottom open 3/4
When you put the zeel in then move to a 130 low
Happy days
Bear in mind there is 1000 different ways to skin a cat and other people have different tunes, my is just based on what works for me
