Routing I think is okay . But def think I have it backwardBut I am referring to just the ends. If you don't have enough cable itself, you may have the wrong one, or have it routed poorly.
Its basically the same for either kaw or yam. I think the longer end goes on the pump end
Thanks sterling . I never knew steering cables could be worse the well worse then anything else I've done on my ski!you're gettin there.... try and take up some slack in the cable ends to center the nozzle. shouldnt hit the reduc nozzle in either direction
