- buffalo ny
I have a blaster that won't do anything when the battery is connected and button is pressed. I checked the fuse, s/s switch, all grounds and connections inside the ebox and still nothing. If I jump the solenoid it will crank over just fine. Going to swap the solenoid tomoorow and see if that does it. What else could be causing this to happen?
