#ZERO
Beach Bum
- Florida - U.S.A.
Has anyone ever tried hooking up an electric fuel lift pump inside the fuel tank with a micro externally adjustable fuel pressure regulator on Mikuni carbs set to about 6 psi?
I'm thinking that this idea would work considering the carb's pop-off pressure is high enough to overcome the fuel pressure and the fact that the SBN carburetor still uses manifold pressure along with air velocity to adjust the fuel mixture.
If you've ever hooked up a fuel pressure gauge between a normal Mikuni fuel pump and restrictor, you'll notice that the pressure gauge fluctuates between 2.5 - 3.5 psi at idle to 4.0 - 5.0 psi at higher rpm. Also, it takes a while for the pressure to build up and can fluctuate erratically at idle on some engines.
An electric fuel pump would always maintain a fixed pressure with FPR for more precise fuel tuning, with the correct jetting and without the instability problems associated with mechanical fuel pumps.
They're a few different small pumps ranging from $20.00 up to $50.00 that draw low amperage and would be suitable for in-tank installations.
