electrical problems 01 rn
I am been chasing electrical problems for the past month. Basically, when I hit the start button the starter turns over really slow and then will start to smoke. So I let off and come back later and sometimes it will turn over fine and sometimes it wont. Lately, I have been hitting it and the solenoid with stick. The starter will keep turning over and smoking until I take off the negative cable to the battery which will in turn blow a hole in my terminal because it gets so hot. My theory is the solenoid melts together causing it to stick. Any ideas why its doing this? I have been through a battery and two solenoids. I also took the starter apart and everything looked fine, but it is a relatively new ebay starter. Any help or opinions? Yes I know buy a nicer starter haha.
OCD Solutions
Rentz, GA
I am going to say you started out with either a bad cable or stuck brushes in the starter and have now burned the contacts in the solenoid as well.
Thanks. Anyway of narrowing it down between the starter and the cable really don't want to pull the starter again. I have to pull the motor and take the bed plate off to get it out or take the exhaust off and buy a new gasket.
TheCoz43
Jet Surfer
Pismo Beach, CA
You can run the cheap starter for 40 and all new cables for 50. Replace both. Prob your cables they go bad a lot. Wont take that long with a buddy and a 12 pack.
Back to the problem again now its getting closer to spring. I replaced the starter with a oem used starter and another new battery and solenoid. The ski ran fine with no issues for 3 weeks cranking it at least once a day. I just went to crank it today and the starter just continues to spin the motor over and will not stop until unhooking the negative battery cable. I still have not replaced the cables. That is my next go to, but I don't quite understand how a short or break in the cables would make the starter continuously turn the motor over.
Bishop CA
My blaster did the same thing when the solenoid died. I pushed the starter button and the starter would continue cranking after the engine was running, Not good!! I disconnected the negative cable and shut it down. After that, if I touched the negative cable to the negative post on the battery, the starter would begin to crank. I replaced the solenoid in the Ebox and this never happened again! Hope this helps!
It does some but i have been through countless solenoids. Today I swapped the cables with no new results I even tried two different working solenoids. Usually with a new solenoid it will work once or twice and do the same thing again.
solenoid is still sticking in closed position OR its highly possible its working correctly , but you are still getting a SIGNAL to the solenoid from somewhere to keep it energized !!!!! did you try disconnecting the wires from the start switch while it was CRANKING , to see if that will make it stop ? ??
I did that also today and it continued to turn over. I took the plugs out and turned it over a couple times by bypassing the solenoid. The battery seemed very low, so I put it on charge while connected to the ski. I continued to turn the motor over bypassing the solenoid. Then I put the plugs and the solenoid back in. Magically it started working again. I have turned it over 20 plus times without the solenoid "sticking". I hate electricity. my guess is its only so long before it does it again.
