- Severna Park MD
I have an electrical problem on my 2010 wamilton superjet and was wondering if anyone could help me with whats going on. I am using the wiring diagram attached. I currently have the starter switch taken apart so that I can jump power across the switch with a wire. On the hot brown wire there is 12 volts but will not start the motor with the switch. With the terminals connected together with a jumper wire the starter motor won’t crank.. On the other terminal there is the brown wire that leads to the starter solenoid; I can jump 12 volts straight from the battery and the starter motor will turn over.When I jump the two terminals with a cable, simulating the start button being pushed, there is a 0 volt difference between anywhere on the brown wire and the ground.
Any help or suggestions are appreciated. Thanks in advance.
