EME 1000 build
Finally... Ive wanted an eme since I test rode one at the 06 world finals. I bought my friends used 07 eme signature series hull after he bought a q8 hull and switched his stuff over. I also called Eric and bought his 05 comp motor which he had just rebuilt. I had been building a waterdawg envy, so pump, pole, powerfactor pipe, tank, cables, steering,etc. was robbed from it and put into this ski. 85 lb hull
Chad lightly reinforced the sides in the areas I usually crack my stuff. We went with some biaxial and covered it with the red carbon kevlor (only color i had).
Luke spent a bunch of time modifying the skat tilt nozzle to actually tilt.
Starting building on Friday, hope to finish today (sunday). Just have a little left.
Looks awesome Tom!!
Can you tell me why you went with a signature hull instead of the Q8?
I could afford this one because it was used, I ridden the q8 and its a spectacular hull but since our lake is usually severe wind chop i love the bigger skis, Last time i rode this ski with steves parts in it, i'd never felt as comfortable on a ski
I finally put it together and rode it. I am so pleased, I still have a few loose ends to tie up but it is the most incredible ski i've ever owned. I couldnt be more pleased.
The power is unreal and the ski handles great. Its officially to much motor for me, but hopefully i'll adapt.
I love this ski.
How does the power compare to the WDK 1200's you've had/ridden?
It's hard to compare because they feel so different, this one revs faster andthe entire set up is considerably lighter than a 1200 envy. When it hits the main powerband , it will violently yank your arms
The sxr style mag pump and sxr hull defineatly processes the water better (lukes 1200 performs better in the envy than the octane hull). I only have 2 gallons through this ski but I need to ride it for a while and compare it to lukes. I'm not sure if it has more hp than lukes but I personally like the setup better than anything I ridden before, the ski is very balanced and nimble, with a crazy fast reving motor, I would be surprised if top speed wasn't 60+
