Eme q8 sky 8,000 Morris Il
Hull is 2011 eme q8 skycarbon/glass construction approx. 75 lbs. New Skat Trak 145 mag pump in 2013. Engine is a Thrust built 4mm stroke 898 Dasa on first bore, about 82 on crank, maybe 32 since new wrist pin bearings and seals installed. Hull is a little beat up as far as scratches and some (not major) stress cracks in gelcoat. Turf job needed. All engine components in good condition. The battery tray is for a ballistic but i have been running a lead acid motorcycle battery for convenience. I made an adapter. I will leave it out and let you decide what you want to run. Ready to ride runs great. Ill forget to check my measages on here and i dont get enough service at work to receive calls I please text 815-715-7450
Dasa 900
48mm Novi carbs
Factory mod pipe opened up to51.5mm, and clearanced for power valves
MSD Total loss with lightened and pinned flywheel by Zero
JS550 gas tank 3.75 Gal.
H2o designs water box
Rule 500 bilge
RRP pole cast
RRP bars and steering
Wamiltons carbon chinpad
Blowsion throttle and trim levers
ODI Ruffian grips
Skat Trak 145 set back 12 vein magnum pump
Skat Trak trim 85mm exit, 90mm steering
Skat Trak 15/20 swirl thin blade prop
$8,000 text 815-715-74606AFA3D6D-54A3-4F6D-AAC7-B72FDD494EE7.jpegAD3B4E6D-8910-43D2-9F23-BBD68ECA7B72.png247E024C-DF04-410F-ACD0-D51CF34EBAED.png5CFD34AB-A60A-4172-BEA4-DAA2FDCF7953.png
