- Eugene, Oregon
Selling because I am a new parent and my hobbies are becoming more family friendly, so I am switching to a boat. The ski is tuned and runs great! This thing will literally rip right out of your arms if you're not paying attention. It has been very dependable to me and handles well! I am able to back flip on a good sized wake.
EME Q8 Carbon fiber hull w/ reinforced fiberglass nose, set up with Yamaha motor/pump.
760cc (GP760 Donor) with .5mm over bore
Freestyle lowered porting by ZForce Racing
Zero Flywheel
R&D Carb Instake Mani no crossover, boyeson dual stage reeds
Dual 44 Mikuni with T-Handle adjustors (115 Main, 120 Pilot, 2.0 N/S, 95g spring)
ADA Girdled head @ 180 psi
Factory B Limited Pipe, 50mm matched porting.
H2O Designs waterbox
The gas tank is one of a kind unique to fit this hull exactly (I designed, cut and welded it).
MSD Ignition
Basically brand new WCF samurai lightweight billet handlepole with chinpad
OVP steering
RRP bars, odi grips, blue billet throttle lever
Carbon XScream Footholds
Front foot tray glassed in
Bilge
Dual 1/2" cooling lines
Worx intake grate
Short and Long ride plates to match your ride style
144mm pump with 9/15 solaris hooker.
The ski has a clean title, registered in OR from a home built application and they put Blowsion down as the manufacturer.
Located in Portland, OR.
$14,000 obo
Zero Flywheel
- 3.2 Gallons
- Has battery compartment which makes it waaaay easier to reach than the original position
- Pro Werks Gas cap
- ADA Racing fuel pick up
MSD Ignition
OVP steering
Bilge
Worx intake grate
$14,000 obo
