- Cleveland, OH
So I've been piecing together this RN hull and running into a few issues.
Finally got the pump aligned and the driveshaft centered in the hole. Took 4mm of shims at the back to do this.
After that, got my motor mounts in and dropped my engine in. With NO shims under the engine the engine's coupler is about 2mm higher than the mid shaft coupler at the top and port side of the hull. On the starboard side it seems like the opposite is true, the pump is higher than the engine. Anybody have a clue what is going on? I've never had this much trouble getting a drive train aligned.
