After I worked on my 2009 SJ engine replacing the crankshaft to HOT ROD after a crankshaft bearing failure, installing new 85mm pistons and new pins instead of 84mm. The engine turned easily by hand without the cylinder head and after I installed the head it became slightly harder to rotate but still it can be turned by hand. The starter motor disassembled and cleaned then put back to its location.
I assumed after I finished assembly the engine will start perfect but unfortunately when I hit the start button the starter relay gave a click sound then I jumped both terminals with a screwdriver and nothing happened so I replaced the relay with a new one after that I hit the start and the engine was cranking very slowly like (half rev, stop, half rev) with plugs then I remover the plugs and it cranked faster than before but still slow. When I thought to check the connections I found that the terminals of the battery and the relay are hot.
Plzzz any advice to solve this issue?
