- Sweet Valley, pa
Been outta the game for a while but totally rebuilding my ski, 2006 sxr
i have had both the wet and dry pipes. i liked the power of the dry...but i hated the coupler system as the orings never last and it always seemed to leak, and i had it shimmed perfect. i like the simplicity of the wet...but it didnt produce as much power. My question to you is is there any reason you cant water jacket the chamber of the wet pipe? i am a reasonably experience TIG welder and have it would actually be quite simple. I have been playing with this thought for a while. my plan would be cut the stock outlet off and weld it shut and make my new outlet out the front of the pipe (like it should be) then simply weld a water jacket around the chamber and run it just like a dry pipe. I originally wanted to run Malones pipe or whatever it is but i am not about to spend 1200 bones for a pipe.
Or does anyone know a dry pipe chamber that i would be able to cut and make fit a wet pipe manifold.
What i am trying to do is make a pipe that makes alot of power with the more reliable coupler of the wet pipe system, i want to use my stock gas tank and would like to keep the weight low in the hull. any type of input is appreciated
