I have had this problem since last year and cannot figure out what is causing it. I am about to just buy new carbs.
every time after riding/running my ski on trailer or in water if it is turned off or dies when i go to start it back up it will be loaded up and typically i have to hold the throttle wide open while cranking then it starts up again and i have to rev it up to clear it out like it is loading up every time it is stopped..
things i have tried to fix this problem..
new carb rebuilds
new needles and seats
made sure everything was the same in both carbs
the motor is: 61x bigbore 85mm, dual aftermarket sbn44s, ada head 35cc domes, stock intake and reeds.
115 or 117.5 Pilot Jets
120 or 122.5 Main Jets
2.3 Needle & Seat
95 Gram - Full Silver Spring
Low Speed – 1-3/8 +/- ¼
High Speed – 7/8 +/- ¼
any thoughts????
new carb rebuilds
2.3 Needle & Seat
any thoughts????
