Super Jet engine question
i have a 2007 yamaha superjet with mods on it , im wondering if i installed prox 83.5mm piston how many cc will my engine be? my cylinder is 62T
Fro Diesel
creative control
Kzoo
You can go 84mm on a 61x cyl. would not recommend it from experience the sleeve is too thin. Also you have to run a different head or 760 domes instead of 701.
Bottom line: there is no advantage to increasing bored unless necessary to clean up grooves and scoring. Dont take a stock 701 at 81mm and go up to 83.5 bc it needs a bore. Unless you enjoy throwing your money away.
