- Galway, Ireland
The driveshaft isn't turning. Not sure what the problem is as ive got very little experience working with engines. anyone have any idea?
Ok ill try that tomorrow too. Would the spark plugs stop the coupler turning by hand?
With the pump removed, you should be able to spin the drive shaft by hand. If the prop is barely scraping on the wear ring it is usually okay (barely meaning, you hear the scraping but it doesn't make the prop any harder to turn). If you can't turn it by hand, I wouldn't go through the trouble of trying to align the pump just yet. I'd get a different wear ring and start over.As far as I can remember it did spin freely. But it was last year I installed it so I can't be sure. I have the pump housing off so ill check the alignment first and see if that does it.
Thanks for all your help guys. Much appreciated
