Engine weight
eastcoastjumper
James
Long Island
Entire Driveline is around 150 lbs engine/pump/shafts/pipe/e box/all cables/mounts etc
Christian_83
Xscream
Denmark
I weighed my TPE 900 CC (4mm LW crank) with MSD FW and MSD dual pickups. PHP intake mainfold and dual Full specs AVLR 49, PFP exhaust manifold. with coupler. Billet SB fW cover with Lexan window
OEM engine side coupler ( can't remember if rubber damper was in) NO STARTER motor (1.9kgs)
So my total engine 35.3kg
My buddy billet DASA 89mm 10mm with same parts, weighed around 1kg more (2.2lbs)
