- Grand Rapids, MI
Ok... stock 701, dual 38s, coffman sizzler, 150 compression, new plugs, spark in both cylinders...
So i took it out for the first time of the year and it ran as it usually does for the first 3-5 minutes. Then it started bogging down a bit and when I hit the gas again it would accelerate slowly to about 1/3 power and just stay there. there is no low end and the engine sounds like it is running rough at times. when it is out of the water it will hit the rev limiter but not when it is under load. It sounds like it is either not getting enough fuel or only one cylinder is running.
I need some ideas, the next things i am going to try are looking at the internal fuel filter and possibly looking at the reeds. Could it be something in the ebox?
It was the first tank of the season so there might have just been debris that settled at the bottom.
Thanks in advance!
Thanks in advance!
