error on http://www.x-h2o.com/ using Chrome
AtomicPunk
Lifetime bans are AWESOME
Largo, Fl
I get an error on http://www.x-h2o.com when using Chrome. If I drop the "www." it works fine. If I use IE9 it works too.
If I use an extended URL it works: "http://www.x-h2o.com/forum.php"
Thats it, I quit.
SuperJETT
none
What kind of error? I just used Firefox, IE8, and Chrome and they all worked just fine.
AtomicPunk
Largo, Fl
not sure....
Warning: require_once(./includes/vba_cmps_include_error.php) [function.require-once]: failed to open stream: No such file or directory in [path]/includes/functions.php(3765) : eval()'d code on line 5
Fatal error: require_once() [function.require]: Failed opening required './includes/vba_cmps_include_error.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/xhocom/public_html/includes/functions.php(3765) : eval()'d code on line 5
SuperJETT
none
This may be a hard one since it doesn't hit everyone.
Try clearing your cache or hitting CTRL-F5 to pull a fresh copy of the page and see if it works.
i recant i get this error when i try tho use "www.x-h20.com" but i never use it since i have my usercp as a short cut on chrome
Fatal error: require_once() [function.require]: Failed opening required './includes/vba_cmps_include_error.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in/home/xhocom/public_html/includes/functions.php(3765) : eval()'d code on line 5
