ET 1107 Single Cooling
Can an ET 1107 be ran with single cooling? Does the motor produce enough heat to NEED dual cooling from two separate lines from the pump or can I use 1 in line from the pump and split that? Sorry for the stupid question!
McDog
Other Administrator
Staff member
South Florida
Probably fine especially if you ride cold water but the dual cooling isnt so much about more water to the engine and pipe. It's more about safety of having redundant cooling lines in case one gets clogged.
