ET 967 with HPE 5 mil kit
Jcary85
Vendor Account
Glenmoore pa
If you can’t get an answer, you might want to just mock it up and start measuring the port timing. You’ll probably be shooting for 195-198 exhaust duration maybe a little higher (guessing - I’ve never measured an ET). Another method is if you have the correct domes for the setup and know target squish, you can pretty easily figure out how much total spacer with gasket thickness you need. What are you starting with? A top end kit and a crank or a blown up motor or what?
i have one. i can measure the spacer plate. and yes mine just uses standard base gaskets top and bottom of the spacer plate. ive been happy with the motor. makes great power for what it is.
