Freestyle ET1107cc Tuning Thread
Please share your success or issues with tuning your ET1107 packages.
Carbs:
Main jet:
Pilot jet:
Popoff:
Needle and seat:
Low screw:
High screw:
Pump:
Prop:
Pipe:
Ignition:
Hull:
I have ran a et1107 for the last 3 seasons great motor from my experience with it makes lots of power.
Et 52mm carbs
125 main
145 pilot
2.0 n/s
Ls 1 1/4
Hs 1 1/2
Tj products 160mm pump
Pfp dry pipe
Cpi Ignition from California Freestyle
Polar Composites Vortex
Sent from my SM-N950W using Tapatalk
Christian_83
Xscream
Denmark
Been running it 3 years with and ADR crank and big reeds setup. Hard to beat the bang for the buck ratio
Carbs: Dual 49mm full specs
Main jet: 135 or 140 i cant remember haha
Pilot jet: 125
Popoff: 22 psi
Needle and seat: 2.0
Low screw: 1
High screw: 1.5
Pump: Skat-trak 155 setback
Prop: 13/18 longblade, thinblade and cutback
Pipe: PFP dry pipe
Ignition: Msd digital total loss
Hull: Nitro Carbon C1
Jcary85
Glenmoore pa
Carbs: Novi 48s
Main jet: 115
Pilot jet: 145
Popoff: 21
Needle and seat: 2.5/115g
Low screw: 1.5
High screw: almost all the way in (would have liked a 110 main jet)
Pump: 155 skat setback
Prop: 8/16 -3mm thin blade
Pipe: PFP dry
Ignition: MSD TL as well as zeel
Hull: Carbon havoc
Sold this ski but I miss it. It was an absolute beast of a motor. Still can’t flip as high on my DVX with an XS1200
denmark
3 years on my 1107 ADR crank
carbs : 49s full spektrum
Ignition : msd tl digital
Jets : 127.5 low 135 High 120 return jet (importen)
NS 1.8 pop off 20 psi
Exhaust : PFP just whent wet pipe
Pump : 155 mag from maxx Setback
Impeller : 12/18 Cutback thin blade
Comp : 190 psi
Nozzel : @PitchComponents trim bore 90 mm steering 94 mm
Hull : comp hurricane
Fuel : pump 100 okt 5 % corn
realy like this engine been solid soo fare, belive higher pitch and comp is possibel with the fuel we have
US
Krash 50 cal
Et1107
Pump 148
Carbs ti50s
125low
130m
Pop 18
Spring black
Ns2.5
Rrp pipe
Jet maniac water box
Gas domes pump
Zealtronic ignition
Sent from my Pixel 4 using Tapatalk
Main jet: 125
Pilot jet: 135
Popoff: 21 psi
Low screw: 1/2
High screw: 3/4
Prop: 9/16 longblade, thinblade and cutback about 9mm
Pipe: PFP wet with inner chamber removed and two spray bars
Ignition: JSTL
Hull: Polar Composites Vortex
Et 52mm carbs
125 main
145 pilot
2.0 n/s
Ls 1 1/4
Hs 1 1/2
Pfp dry pipe
What size is your fuel tank and how long does it last with the 52s?
Krash 50 cal
1200 Dasa
Carbs: Thrust 50's
Main jet: 120
Pilot jet: 135
Popoff: 21
Needle and seat: 2.0 , 80 black spring
Low screw: 1/2
High screw: 1
Pump: Skat Track 160mm , thrust nozzle
Prop: 7/14 , long blade , thin blade cut back 5mm
Pipe: PFP wet
Ignition: MSD total loss
2020 ET1107 about 20 hours, ET crank.
200psi
50/50 110-91 octane
Carbs: Dual 49mm full specs, oem pumps(for now)
Main jet: 120
Pilot jet: 137.5
Popoff: 26psi 70 return jet.
Needle and seat: 1.8
Low screw: 3/4
High screw: 1/2
Pump: Skat-trak 155 setback, pee pee trim.
Prop: 6/14 longblade, it’s to loose.
Pipe: PFP dry, rrp box.
Ignition: Stock charging, 3mm advanced, MSD enhancer, jetnetics flywheel.
Hull: Rickter XFR glass
Messed with larger or no Return jets but always seems to run out of fuel on combos.
Full specs always seem to dribble a little to a lot.
Rips and can somewhat combo, but can still has more potential to be unlocked.
@SmittySX do you have a 1107 with a formula that hits? Or asking for a friend
Jcary85
Glenmoore pa
200psi
50/50 110-91 octane
Main jet: 120
Pilot jet: 137.5
Low screw: 3/4
High screw: 1/2
IMHO your nuts running that on an enhancer. You’re leaving tons of power on the table and it’s risky given how much timing they run in the upper RPMs
denmark
200psi
50/50 110-91 octane
Main jet: 120
Pilot jet: 137.5
Low screw: 3/4
High screw: 1/2
6/14 that is almost a sub 800 cc prop you need too pitch up
Comp : 190 psi
Have any footage?
Jcary85
Glenmoore pa
Have any of you guys had your 1107 cylinder ported?
Ported how? Widening the exhaust port? Changing port timing? Art has these things pretty well dialed in. He did mention he can raise the exhaust port slightly if you want more of a race motor. I don’t think there’s much gain to be had by screwing with his porting (I did ask him about this back when I ordered my 1107 - was curious if I could pay more for some secret sauce extra porting but it sounded like there wasn’t much left on the table). Do you just mean smoothing out the port work a bit?
