exhaust manifold trick
jetski9010
Team RTYD
Lancaster PA
so I was talking to a guy that use to build race snowmobile motors in the 80's. He was telling me about a trick they use to do before power valves came out. He said he would blueprint the exhaust manifold to the cylinder but then at the bottom he would cut the manifold down 4-6mm lower so when the sound wave came back it would hip this lip and be forced upward to help block in the fresh charge as much as possiable. He said this mod helped out with torque. Is this already a well know mod out there? Would this work the same on a jet ski engine?
jetski9010
Team RTYD
Lancaster PA
Now after hearing this I was looking at the exhaust ports of some 62T cylinders and it looks like they have a very small 1mm lip on the bottom. I wonder if this is the same theory behind this.
SUPERTUNE
Race Gas Rules
Clearwater Fl.
If you use unported 61x cylinders and a unported Factory B pipe manifold, you would almost have the same thing as they don't match up very well stock.
Roo
it's all good
So on a setup such as this...
don't port match the manifold to the cylinder?
just *perhaps* open up the exhaust manifold outlet and head pipe (factory b pipe?)
GIL
Power In The Hands Of Few
Cullman AL
I think you would want to port match it everywhere eles just leave a lip at the bottom.
Dan has my 'lips' at the leading edge of both exhaust ports. He says it is to help w/exhaust reversion. If you do a search on posts started by me there is pics of it somewhere on here.
waxhead
wannabe backflipper
gold coast
Ok not some thing i have done
But when you consider that that the exhaust gases and fresh air goes out of the engine and into the exhaust
not only will you be blocking new air in but also new air out
GIL
Cullman AL
It doesn't have to.
People just have to think it works.
I am pretty dam sure my 'lips' are due to mis-alignment during the casting process. Why in the hell would you get the port alignment that far off? We are talkin a 1/4" on one hole and 1/8 on the other. I am pretty sure I was fed a line of B.S.
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
Interesting idea, but I really doubt it works. The idea of a tuned pipe on a two stroke is to push some of the fresh air charge that sneaks through to the exhaust back into the combustion chamber before the ex port closes. The only way this will happen is if the positive pressure returned by the pipe is greater than that in the combustion chamber (and that it's timed right). Well, putting a sudden contraction in the exhaust on the way back into the combustion chamber is going to rob you of some positive pressure produced by the pipe, not add to it. It may not sound like it, but this is pretty simple fluid mechanics.
