Was wiggling my exhaust tube from inside the hull and noticed daylight shining through. Turns out the epoxy broke. Some was still adhered to the hull and some to the exhaust pipe itself so it's not like the surfaces weren't prepped.
I did hear that if you run your pipe too hot it can soften the epoxy.
My question... What's the best way to go about it? There is no bulkhead so the only area it's supported is the back of hull and the connection point, so it has the potential to have a lot of flex. That makes me not want to use epoxy, also due to the heat factor. Would my best bet be using 5200(or 4200 because 4200 is rated for metal to fiberglass bonding and 5200 isn't?)
I need structure and flexibility I assume..
Any advice is much appreciated. This is after 3 seasons of use.
Here's the open bulkhead style I'm dealing with. Plan on adding a longer metal exhaust tube while I'm at it...
Thanks!
Thanks!
