Exposed Carbon Helium XScream 1400 RTR
sjetrider
Built and tuned by Tricky for Tricky, was purchased from Tricky last fall, rode 3 times (absolutely nothing changed since purchased) helium2.jpghelium5.jpghelium1.jpghelium7.jpg
Current owner says "ITS TOO MUCH"., which i understand as its too much for me as well. You want ZERO excuses, here is your machine. All the right stuff, 1400cc with 162mm xmetal pump and all the right stuff in between. If you are considering it then you already know what it is. Come ride it and take it home. $30K its in Nashville TN and ready to rip.
Utah
Hi Sjetrider,
Do you have a full build list for the ski? When was it built? Were all the parts new? What size are the footholds built for?
Thanks,
sjetrider
I can ask Tricky if he has a build list.
size 10 on footholds. Current owner size 11 and was fine. PM me if you would like my number to call or text.
Utah
Thanks for the add'l info. I'm still trying to decide how serious I am, so I won't bother you yet to reach out to Tricky, but will let you know soon if I'm serious enough for you to do that. It's a great looking ski, but still trying to figure out if 1400 is the right call for me. Thanks again
sjetrider
I can tell you all this ski is in incredible condition, runs and hits like it should, i do not believe there is much time on the 1400, I know there isnt since purchased from Tricky1 on here. He is a trusted builder and built this for himself and appears zero expense was spared. there has been aprox 10gals run through it since purchased last fall. When current owner wanted the BEST i steered him with confidence to this purchase and would do the same to another friend if they want A BEAST of a ski that gives you NO excuses. I am not even a novice freestyler and i can and have done 540's and flipped this ski on flatwater WITH EASE! if i were a flatwater only rider i would own it! Hull is in incredible condition as well. If you want you can PM Tricky1 and maybe he can elaborate more.
1400 latest version
52mm Xscream carbs
PFP
MSD TL
162mm i believe titanium xscream pump
Xscream trim system
I am pretty sure the owner will entertain offers, he isnt on here and knows less about the ski than i do, he just knows it HURTS GOING THAT HIGH!
if its what your looking for just come ride it and you will buy it.
Anymore info PM Tricky1 he may answer your questions.
