Ed is one of the guys that always recomends the separate FP. If you are looking at the throry talk to him, if not you can look up the fuel of the 46's pumps and the remote pump and see that the remote pumps more fuel. Pressure should not shcnage at as all the restrictor is the same. I personally feel that the larger fuel pump is more geared towards race, I ahve had no issues at all witht he individual pumps, that being said all major competitors use the remote pump. With that for the rest of us, does it really matter? Forget the minute details, 100% race gas, 245psi, 38 deg timing, 162 mm pumps, etc. Do you really need that to go out and ride with your buddies? Sure it makes for good reading, and discussions, and if you are one of those guys that has to have the 2000HP car in the neighborhood, but in reality we are brapping around 90% of the time and trying some tricks. Concentrate on the riding, that is key.
To answer the question: advantage fuel delivery, possible gains. disadvantage: cost, pumpbing changes. Duals require a 5/16" feed line, mnost tanks are set for 1/4".
