Factory B-Pipe head pipe clogged.... HELP!
I have a B pipe head pipe that is clogged up pretty good. Water flows through, but not all the way around to cool it like it should. What can i use to try to get it clear again? Tried soaking it in salt-away but it didnt help.... any ideas?????
Thanx in advance-
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
This is a long shot, but what about pouring some CLR (bathroom Calcium-Lime-Rust remover) down the water passage, let it soak for a few hours and then blow it out with compressed air and then run some water through it......
tor*p*do
Squarenose FTW
NW NC
muriatic!
burns holes right hrough the water jacket!!! :kabong:
try vinegar which is mild acetic
