Lival
Build build build
- Connecticut
What is the difference between the limited and mod version of the bpipe?
The mod chamber is about 1.5" shorter than the limited version and that is the only difference. I've taken limited chambers , sawed out a section 1 3/8 long and welded it back together. The shorter chamber is easier to install, used to be used for racing. You don't loose a whole lot of bottom end depending on your engine setup. You should use the longer limited chamber for freestyle.
