SXR Factory Pipe O-rings
Texan33
Yacht Wakes Hunter
Texas
Hello, guys.
I was wondering if anyone know what's the durometer hardness of those o-rings used for the sxr dry pipe. I keep destroying the o-rings in my dry pipe nearly every ride. I don't like how soft and flimsy those rings are. I'm trying to determine the durometer of the o-rings so I can order a higher durometer rings.
Also, the correct sizes of those o-rings are buna 334, 337, and 341?
Thank you,
Tyler
align your pipe with coupler.o rings should last a long time and seal better as they seat and wear up to a point.move your mounts or shim them as needed and run a 650sx coupler and 2 hose clamps for a complete seal.
also check the integrity of the lord mounts.
once all lined up the mounts should push the pipe slightly forward to compress the o rings.
