Fiber gaskets compress better when torqued , so in my opinion, will seal better under a low torque and normal compression application. Although, if you're running high compression for performance, you will need a copper head gasket and some 1211 to seal it with. Regardless of which type, When you install it, makes sure you clean all of the mating surfaces good with a very "hot" based solvent like lacquer thinner, chemtool B-12, etc.. And by "clean" I mean go over the same surfaces with a new rag area like ten times. Even though you can't usually see it with the naked eye, mating surfaces are porous and like to soak up oil residue. If they're not cleaned thoroughly, it will cause sealer to fail by not allowing it to cure to the surface(s) and grip them properly.
Also, if you're using 1211 sealer, allow it to set up for a full 24 hours in a moderate temp environment, before exposing it to compression and combustion pressures.
