ski_crazy
ISJWTA member #5
- Holts Summit, MO
I couldn't find a write up on fitting a RN hand pole to a Kawi 750 sx, sxi, or sxi pro hull. So here goes. Start with a stock RN pole (thanks to Aqua for the hook up)
First I cut about 1/4" off the bottom tip of the pole. Placed in a chop saw squared up makes a nice clean cut.
After that was removed you need to grind a little off the corners. Rounding the corners help to match the contour of the factory pole bracket.
Inside the stock pole bracket there is a nub that needs to be ground down so the RN pole can have full movement all the way up. Before grinding
After grinding
After grinding
