Hi guy's, here is my sn this weekend i go to test and setup in water.
Thanks for Jetmaniac and #Zero for good parts and counseling!! and for all of you coz your post are very helpful !
First i setup the engine for surf and i running factory B pipe, 30cc domes and R&D intake with 44's blackjack's.
But now i make it more agressive for flat water and i run with 35cc domes and the power factor.
The engine is 771cc with #zero freestyle big bore sleeves, cases and cylinder casting bored.
I run the engine cold adding 2 more fitting's in the head and more piston clearance.
now i have a oem intake with aftermarket sbn 44's reverse jetting's.
Msd enhancer with 62t stator and oem lightened flywheel, ada couplers and a 650 crank welded with hot rod's.Here some pic's:
