i try it whit no shim in,it suposed to open easely^^was it flowing above 3 psi?
put one on mine an ended whit a blown gasket coupler an a melted foam under the water box....on the first ride......some said my head pipe screw was to closed on the bottom....i still got the valvle but afraid to put it back on...
how to test, and how to adjust....only got shim in
i run the one whit shim version,and make everything melte last season........maybe my pipe run too hot,i run my pipe near close to the bottom,now i opened it to 1/2,maybe its gonna be better....
