- Newzealand
Hey guys!
I've mainly been developing this for the mini jetboat crowd but it may be of some interest for the skis aswell, I'm not sure if anyone has ever looked at going this route but it offers a few advantages over the standard diverter after nozzle configuration.
Pictured is billet stainless to retain a small footprint while still being durable enough to deal with pumping abrasives and debris but I'd be happy to do a run of aluminium if there's enough interest to suit jetskis pumping clean water!
Having the pressure generated directly before the exit means you're not fighting a pressurised Jetstream to turn or trim. Nozzle size can be changed by simply swapping out the insert, this nozzle can go from 70mm upto 90mm.
Clearance between the bowl and deflector is no more than 0.5mm throughout all motion of the nozzle to maintain pressure and accuracy.
I've used a mix of delrin bushes and stainless bearings for a very light and positive steering feel.
Feel free to ask any questions or make suggestions
