Want to Buy Fly wheel lock and puller for Yamaha
You should be able to get a cheap harmonic balancer puller. Those aren't hard to find. I've always used the rope in the cylinder trick instead of the flywheel lock, but will soon buy the lock, because I do a fair bit of engine work. If you're only going to use it only a couple times, I'm not sure it's worth it.
Ohio
Yep local for puller and tomski or jetmaniac for lock (in stock with them) or others I imagine. I can't believe I waited so long either!
  • Like
Reactions: Tau
