SXR flywheel
its worth the 500$ ?
Closer to $600 isn't it? Either way, expensive and honestly, overpriced. With that said, what other options are out there? I've heard of some problems with the Jetnetics, but no personal experience. The TBM will make a difference, although whether that difference is worth the cost can only be answered by you. I like mine.
djkorn1
kidkornfilms
Cleveland Ohio
I have a TBM charging flywheel and love it! No difference in top speed that I noticed, but definitely a big difference in BRAAP.
Yep. Huge low end gains.... #Zero takes alot of weight off, especially if you go TL, If I was hurtin for $ I'd go that route, but as far as I'm concerned, the best gains I've had is...
1. Lightweight hull
2. Pipe
3. Flywheel
