Go with sheets for sure
Are the sheets precuts?
NOOOO lol. just get regular old sheets
to save some money you'll be better off just buying the turf and two sheets of padding online. I used 8mm on the tray and 5mm on the sides and dash. the epoxy can be bought from your local hardware store. use weldwood in the red can, it works better than the blowsion stuff.
precut sheets might save a little time but are typically cut too short and leave gaps. if you go through the trouble to put in turf and holds might as well make it look pretty too.
i'm about to order everything for this project as well, do you think two sheets would cover the tray, sides, and rails? or should i go with 3? Thanks
Edit: Where did everyone order the under padding from? I don't see it on blowsion.
