- maitland, fl.
2001 hull w/ X-Scream lightweight lowered Hood and Nose
X-Scream shortened Aluminum pole
X-Scream nose bracket
Handlepole spring
Cold Fusion hood hooks
718cc Blueported/Jet Maniac motor
82mm pistons (200/200 psi)
ADA/JetManiac girdled head
w/ 35cc domes
MSD Ignition
38mm duel carbs
B-pipe
JetManiac Waterbox
Hooker Impellar
Straight Bars
Blowsion finger throttle
ODI grips
Bilge pump w/ handlebar switch
Dominator rideplate
Extra D-cut rideplate
Worx intake grate
Blowsion gas cap
Primer
Footholds
New fuel line
New Lithium baterry
Located in Central Florida
$7,400
Sent from my SM-G975U using Tapatalk
Handlepole spring
w/ 35cc domes
MSD Ignition
38mm duel carbs
B-pipe
JetManiac Waterbox
Hooker Impellar
Straight Bars
ODI grips
Dominator rideplate
Worx intake grate
Blowsion gas cap
Primer
Footholds
New fuel line
New Lithium baterry
$7,400
