UneducatedFX1
X-H2O
- Canada
So i have a Gp1200 which is fuel injected and was wondering could i pre mix or do i need to stay with the oil pump?
If it is fuel injected, I wouldn't…
Carbs take a simple slight turn to increase the fuel-dump…More oil = Less fuel --> Lean burning = potential piston seizure
Helpful Photos for post-BOOM analysis:
http://www.smellofdeath.com/lloydy/piston_diag_guide.htm
-Gringo
EDIT: Unless you have the capability to increase the Fuel Injection fuel-dump (i.e. MegaSquirt Module)
The gp1200 is carbureted. The gpr1200 and gpr1300 are fuel injected. So a gp1200 with fuel injection would be unique.
Fuel injected motors do not have carbs so you can't just adjust with screws. They have throttle bodies which look like carbs but they are not the same.
Have yet to see a fuel injected gpr 1200
I know the 1300 was but are you 100% sure the 1200 is
