- Illinois
So I just recently put a stock 61x/61x motor (pulled from a vxr pro) into my '91 square nose hull in place of the stock 650. I swapped ebox over too so it does have 701 cdi. Kept the 650 carb but changed all the internals over to stock 701 specs. Everything else is the same from the 650. My buddy has a bone stock '06 round nose and it has quite a bit more power everywhere. Is a dual carb 61x/62t gonna have more low end punch than a full 61x with stock single carb? I talked to a guy and he said changing out the 650 exhaust tube for a 701 tube will make a difference in low end. Is this true on a stock motor? also looks like yamaha used a different (larger?)exit nozzle on the pumps starting in 93? Pump and prop look to be in good shape to the eye but I have no idea what the pitch is. I want to keep the motor stock for reliability reason, what do I need to do to make this thing hit harder off the bottom end like my buddies round nose? ...I will eventually be getting a b-pipe but thats down the road.
Also Anyone have a good prop recommendation for freeride with a stock 61x??
