Anyone bore there nozzle out on the FX-1. Doesn't look like there is much meat there to bore. Is there a safe proven size that is possible? Don't want to break the steering nozzle mounts off.
Funny you should say that, I just picked up an fx 1 this month and that nozzle I did have should I say is now gone. The size is basically the same size as the I hole that is right next to it. I'm 200lbs and I have noticed it is still strong, so far... I've only been on it twice from the weather. Was that a spray nozzle like the old sit down ski's had?
The small outlet you are refering to is for the yamaha fountain. What I'm refering to is the large pump exit nozzle. Boring this will allow more water to flow increasing bottom end thrust. I increased the bore 2mm anyway and is seems to have plenty of meat left.
