FX-1 FX-1 steering cable vs. RN steering cable
smoofers
Rockin' the SQUARE!!!!
Granbury, TX
What if you were to swap in a 96-07 RN pole?
Is the pump section length any different?
I know the handle pole top is shorter on the 08+ and FX1. Is that the only difference?
Pump is different, too.
I ran an FX1 pole on a SN a while back.
I made the pump end work by putting an extension on the threaded part.
So if you want to run a 90-07 cable in an FX1, you'd have to somehow shorten & rethread the cable.
