LS86
LKN
- Sherrills Ford, NC
I just bought a fx1 with front exhaust and I am going to switch back to rear exhaust and will need the metal tube and the rubber hose from waterbox to metal tube.
I'm not sure on the rubber tube, I would say the stock length. There is one on Ebay right now I'm looking at.Years ago I tried to pull the metal exhaust tube just for paining reasons and ended up destroying it. i Think they are Installed better in the FX1 than in the SJ.
Anyway, I ended up buying a piece of fiberglass tubing from a boat shop and glasses it in. Looked pretty cool out the back actually because there was no seams.
It has been along time since I’ve been under the hood of an FX1, do you know the approximate length of hose that you need? I have a long section of exhaust hose from a Blaster that may work for you. I’ll try to get some measurements later.
